Hi Everyone,
I’m just doing my research before changing our core PFsense router over to a Mikrotik RB1100. To help get things moved across smoothly I’m making sure I know how to implement the current config on the Mikrotik.
Currently we have a /30 for a point to point to our ISP delivered over ethernet. We also have a /29 and /28 that are statically routed to us. At the moment PFsense has all of the public IP’s in the /29 and /28 assigned to it as Virtual IP’s (proxy ARP). We have two local subnets attached to the pfsense box (192.168.11.0/24 and 10.23.1.0/24) which are default NAT’d to two different public IP’s.
When we add a server that requires a public IP we assign it an address in the 10.23.1.0/24 subnet and use 1:1 NAT to forward all ports or we just forward specific ports and block the rest. When we do this we also get PFsense to set the outbound NAT as its assigned IP so any outbound connections come from the assigned public IP instead of the default one.
As an example -
xxx.xxx.132.8 ← 192.168.11.0/24
xxx.xxx.132.9 ← 10.23.1.0/24
xxx.xxx.132.10 ↔ 10.23.1.5 (1:1 NAT)
On our WAN interface, do I need to assign all of our /29 and /28 public IPs like below? Should they be entered as /32’s?
### WAN address from the /30 ###
/ip address add address=xxx.xxx.132.6/30 interface=Wan
### Addresses from the /29 ###
/ip address add address=xxx.xxx.132.8/29 interface=Wan
/ip address add address=xxx.xxx.132.9/29 interface=Wan
/ip address add address=xxx.xxx.132.14/29 interface=Wan
### LAN subnets ##
/ip address add address=192.168.11.254/24 interface=Lan1
/ip address add address=10.23.1.254/24 interface=Lan2
From here the NAT should be straightforward?
### Nat the 192.168.11.0/24
/ip firewall nat add chain=srcnat src-address=192.168.11.0/24 action=src-nat \
to-addresses=xxx.xxx.132.8
### Nat the 10.23.1.0/24
/ip firewall nat add chain=srcnat src-address=10.23.1.0/24 action=src-nat \
to-addresses=xxx.xxx.132.9
### 1:1 NAT the server at 10.23.1.5
/ip firewall nat add chain=dstnat dst-address=xxx.xxx.132.10 action=dst-nat \
to-addresses=10.23.1.5
/ip firewall nat add chain=srcnat src-address=10.23.1.5 action=src-nat \
to-addresses=xxx.xxx.132.10
If I’ve stuffed up anything please let me know ![]()
Thanks guys
-Matt
