Hi guys, i new in this forum and i new in Mikrotik World ![]()
I have a problem, if someone can help me I appreciate…
See the following situation…
Mikrotik is the gateway: 192.168.1.1
ADSL PPPOE Connection: xxx.xxx.xxx.xxx or xxx.no-ip.org
Specific Server Service in my LAN: 192.168.1.4
192.168.1.x (ALL PCs in LAN) access → 192.168.1.4 OK!
Any External Address (Internet) → 192.168.1.4 OK!
192.168.1.x → xxx.xxx.xxx.xxx (xxx.no-ip.org) NOT WORKS ![]()
I want access my service for both destinations, 192.168.1.4 or to xxx.xxx.xxx.xxx or xxx.no-ip.org
Exemple…
192.168.1.4:3389 (RDP)
if one LAN PC (192.168.1.10) try access the 192.168.1.4:3389 internally OK, this works!
if one WAN PC (Internet) try access the xxx.xxx.xxx.xxx:3389 or xxx.no-ip.org:3389 OK, this works!
if one LAN PC (192.168.1.10) try access the xxx.xxx.xxx.xxx:3389 (xxx.no-ip.org:3389) NOT WORKS!
if i ping xxx.xxx.xxx.xxx or xxx.no-ip.org from any LAN PC, Works but i not connect ![]()
I use a specific service and I need to connect the two forms locally.
NOTE: If i use a common Router like TP-Link, Works OK!
Someone can help me??
Thanks!
