Hi everyone, I think I will buy a mikrotik RouterOS very soon, but I wonder if there’s a way to be transparent for P2P connections, because in the feature list I saw nat helping for some protocols, but can’t find which protocols. I know that uPnP can do something like that, however not every protocols support it.
I would have support for at least kazaa, edonkey/bitTorrent (this one can use uPnP), and SIP.
Thanks, I’ll surely use the demo to check features. Last question, is there a way to add service-port (is there available packages, or a way to build new ones ?)
Yes, that’s what I understood, but all protocols are not uPnP capable… And I don’t know if many users with same software will be supported, does uPnP allocate different ports per user ?
it’s not said that your p2p programs won’t work without NAT helpers or UPnP. In fact, all programs work anyway. The only difference without a Nat rule could be “low id” or “firewalled” status in your program, but it would still work. UPnP makes dynamit NAT rule based on whatever the program tells it.
Yes, I now how P2P and nat works together, but my question is, imagine that I have several users that are using the same P2P application with uPnP, so their client are asking for the same ports, does the router negociate a new port for each client, or only the first client will be allowed to access the service ?
Anyway, thanks for your fasts replies, I think mikrotik is what I’m looking for.
