NAT IP don't show real visitors IP
Hi folks,
I checked several threads about same problem but I didn’t succeeded to solve my problem.
I have Mikrotik board-name: RB2011UiAS-2HnD
On that Mikrotik, I have several public IP’s.
Each of the public IPs was NAT on some private IP, usually on some Linux server.
I need to set NAT that I can see visitor’s real IP in logs instead of router IP.
This is IPs:
#   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.1.1/24     192.168.1.0     bridge
 1   147.xx.xxx.74/29    147.xx.xxx.72    ether1-lan
 2   147.xx.xxx.76/29    147.xx.xxx.72    ether1-lan
 3   147.xx.xxx.77/29    147.xx.xxx.72    ether1-lan
 4   147.xx.xxx.78/29    147.xx.xxx.72    ether1-lan
This is my firewalls rules:
 0    chain=dstnat action=dst-nat to-addresses=192.168.1.211 dst-address=147.xx.xxx.77 dst-address-type=local
      in-interface=ether1-lan log=no log-prefix=""
 1    chain=dstnat action=dst-nat to-addresses=192.168.1.200 dst-address=147.xx.xxx.78 in-interface=ether1-lan log=no
      log-prefix=""
 2    chain=dstnat action=dst-nat to-addresses=192.168.1.207 dst-address=147.xx.xxx.76 in-interface=ether1-lan log=no
      log-prefix=""
 3    chain=dstnat action=dst-nat to-addresses=192.168.1.208 dst-address=147.xx.xxx.75 in-interface=ether1-lan log=no
      log-prefix=""
 4    chain=srcnat action=src-nat to-addresses=147.xx.xxx.78 src-address=192.168.1.200 log=no log-prefix=""
 5    chain=srcnat action=src-nat to-addresses=147.xx.xxx.77 src-address=192.168.1.211 out-interface=ether1-lan log=no
      log-prefix=""
 6    chain=srcnat action=src-nat to-addresses=147.xx.xxx.76 src-address=192.168.1.207 out-interface=ether1-lan log=no
      log-prefix=""
 7    chain=srcnat action=src-nat to-addresses=147.xx.xxx.75 src-address=192.168.1.208 out-interface=ether1-lan log=no
      log-prefix=""
 8    ;;; defconf: masquerade
      chain=srcnat action=src-nat to-addresses=147.xx.xxx.74 out-interface=ether1-lan log=no log-prefix=""
I need when someone loging over public IP 147.xx.xxx.77, because that IP was NAT to private 192.168.1.211 that I can see in logs real visitor IP address instead router IP 192.168.1.1
Thank you.
I solved problme with this rule:
chain=srcnat action=masquerade out-interface=ether1-lan log=no log-prefix=“”
Interesting issue.
However I do not understand why the router logs would NOT show the external WANIP making an incoming server request on port xxxx???
The solution seems plausible in that return traffic from the server outbound should have the originators IP in the traffic.
