Nat is driving me crazy
Hello everyone.
Please can you help me, this is going to kill me.
I need to have 2 services running via one external IP, each service using different ports, on different devices. Some udp, some tcp. How would this be done?
Pls, i know this might seem simple, but i have to get this working. Everything i have tried does not work.
Maby an expample that i can change the ips to suit my needs.
Thanks a mill
firewall - nat - add - dstnat - dst-address=your_external_address, dst-port=your_port, action = dst-nat, to-addresses = your_internal_ip, to-ports = your_internal_port
Also make sure Connection Tracking is enabled. NAT won’t work without it.
I have the same problem.
my firewall config:
 0   chain=srcnat action=masquerade src-address=10.50.0.0/24
 1   chain=dstnat action=dst-nat to-addresses=10.50.0.2 to-ports=4899
     in-interface=ether1 dst-port=7001 protocol=tcp
my ip config
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   40.0.10.251/24     40.0.10.0       40.0.10.255     ether1
 1   10.50.0.1/24       10.50.0.0       10.50.0.255     ether4
connection tracking
enabled: yes
      tcp-syn-sent-timeout: 5s
  tcp-syn-received-timeout: 5s
   tcp-established-timeout: 1d
      tcp-fin-wait-timeout: 10s
    tcp-close-wait-timeout: 10s
      tcp-last-ack-timeout: 10s
     tcp-time-wait-timeout: 10s
         tcp-close-timeout: 10s
               udp-timeout: 10s
        udp-stream-timeout: 3m
              icmp-timeout: 10s
           generic-timeout: 10m
             tcp-syncookie: no
               max-entries: 524288
             total-entries: 4
Please help!!!
This should help you
chain=dstnat dst-address=40.0.10.251 action=dst-nat to-addresses=10.50.0.2 to-ports=4899 dst-port=7001 protocol=tcp
also got a problem with dst nat. Its set up like Chupaka posted and connection tracking is on.
When I connect to my external ip from another computer its able to display some of the page, but very very slowly and the pictures fails. Also I noticed that IE displayed my internal ip at the status bar when it loads the page..
Im using a rb112, ros v3.3. This setting worked fine earlier (v 2-9), but as I didnt need the dst nat for some time it was disabled until now..
