NAT issue
What device if issuing the IP/DHCP server? Is it the Cisco or Mikrotik?
After i’m finished setting up the Tik am configuring PPTP-BCP layer 2 vpn through the MPLS router and it require’s that the LAN port must be add to the bridge
thats why i assign the ip add to the bridge not to the LAN interface.
I’ll give it a shot and try configuring /30 between the gateways and the Tik with a proxy-arp and see what happens.
In my environment we aren’t using a dhcp to assign ip addresses, we use static addresses.
Hello sindy
am still struggling with my problem.
would it be ok if i gave you access to my router via anydesk to check it out?
I have no problem to connect remotely (TeamViewer would be preferred, though), however bear in mind that I don’t use hotspot so at least the beginning would be a try and fail business. Worse than that, I’m also still not sure I fully understand the use case.
Oh yes, and my knowledge of Arabic is limited to “yes, no, thank you, maybe tomorrow, there is no electricity”.
So think twice; if you still want to give it a try, tell me whether you can use commandline openssl on some Linux or Windows system to send me your direct contact in a secure way.
