I am having weird nat issues. If I reset the switch & configure a basic wan & LAN interface with NAT enabled via winbox, I can ping Internet addresses, dig & update my OS. Once I start adding DST nat rules to access computers behind the wan ip, I can no longer update my os yet I can still ping & resolve. I have to enable IP fragment to run updates. I then removed the masq nat & set up src nat to access internet & access machines behind ip. I still cannot update.
my very basic setup is as follows:
jun/12/2020 11:17:50 by RouterOS 6.44.5
software id = BP1D-Z2VM
model = CRS125-24G-1S
serial number = 944F09C6EEE5
add name=bridge1
add name=WAN
add name=LAN
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
add bridge=bridge1 interface=sfp1
add interface=ether1 list=WAN
add address=192.168.3.57/26 interface=ether1 network=192.168.3.0
add address=192.168.8.2/26 interface=ether2 network=192.168.8.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1
set servers=8.8.8.8
add action=accept chain=forward connection-nat-state=dstnat connection-state=
established,related
add action=accept chain=input disabled=yes dst-address=192.168.8.6 dst-port=22
log=yes protocol=tcp
add action=accept chain=forward disabled=yes dst-port=80 log=yes protocol=tcp
add action=accept chain=forward disabled=yes dst-address=192.168.8.6 dst-port=
5240 log=yes protocol=tcp
add action=drop chain=input connection-state=invalid log=yes
add action=src-nat chain=srcnat fragment=no log=yes out-interface-list=WAN
src-address=192.168.8.0/26 to-addresses=192.168.3.57
add action=dst-nat chain=dstnat dst-address=192.168.3.57 dst-port=22 fragment=
no log=yes protocol=tcp to-addresses=192.168.8.6
add action=dst-nat chain=dstnat fragment=no log=yes protocol=tcp to-addresses=
192.168.8.6 to-ports=5240
add action=dst-nat chain=dstnat disabled=yes fragment=yes log=yes protocol=tcp
to-addresses=192.168.8.6 to-ports=10000
to-addresses=192.168.8.6 to-ports=443
add distance=1 gateway=192.168.3.3
