Hi!
I have to log all NAT activities (ip to ip, ports, etc.). How should i set it, because i already have tried all log settings, but i didnt find the good one.
Thanx
Hi!
Thanx
to log all traffic that applyied to NAT rules, you have to place the following rule at the top of NAT rules list:
/ ip firewall nat
add chain=srcnat action=log log-prefix=“SRC-NAT” disabled=no
add chain=dstnat action=log log-prefix=“DST-NAT” disabled=no
But you should be prepared to get a lot of data that way - do you really want/need to log all that stuff?
Best regards,
Christian Meis
thank you very much.
i have to log it because of laws! ![]()
Where are you located (just out of curiosity)?
Best regards,
Christian Meis
Hello,permit my english
Please i need some help on NAT i have a server with the 10.0.0.2/24 and i need to access it from outside with this IP address 63.109.247.27 i use this rule below but i was not able to use it to evrn browse the net and not able to access it from the internet there is no firewall on the Mikrotik if i use src-nat ip firewall nat add chain=srcnat out-interface=Cyber_Net action=masquerade it will browse but when i remove it and use this /ip firewall nat add chain=dstnat dst-address=63.109.247.27 action=dst-nat to-addresses=10.0.0.2
/ip firewall nat add chain=srcnat src-address=10.0.0.2 action=src-nat to-addresses=63.109.247.27 it will not work can any one please help me
Hello Sir,
HU. we’re ISP.
