Suddenly something changed. I am trying to acces my internal machine from outside. But I can’t ssh to it anymore. My machine is 10.1.0.203 and the port forwarding is on 1234 port .From inside LAN, web surfing is ok
This is my filter chain:
0 ;;; default configuration
chain=input action=accept protocol=icmp log=no log-prefix=""
1 ;;; default configuration
chain=input action=accept connection-state=established,related log=no log-prefix=""
2 chain=input action=add-src-to-address-list protocol=tcp address-list=blocked-addr address-list-timeout=1d connection-limit=200,32 log=no log-prefix=""
3 chain=input action=tarpit protocol=tcp src-address-list=blocked-addr connection-limit=3,32 log=no log-prefix=""
4 ;;; SYN Flood protect
chain=forward action=jump jump-target=SYN-Protect tcp-flags=syn connection-state=new protocol=tcp log=no log-prefix=""
5 chain=SYN-Protect action=accept tcp-flags=syn connection-state=new protocol=tcp limit=400,5 log=no log-prefix=""
6 chain=SYN-Protect action=drop tcp-flags=syn connection-state=new protocol=tcp log=no log-prefix=""
7 chain=forward action=jump jump-target=block-ddos connection-state=new log=no log-prefix=""
8 chain=forward action=drop connection-state=new src-address-list=ddoser dst-address-list=ddosed log=no log-prefix=""
9 chain=block-ddos action=return dst-limit=50,50,src-and-dst-addresses/10s log=no log-prefix=""
10 chain=block-ddos action=add-dst-to-address-list address-list=ddosed address-list-timeout=10m log=no log-prefix=""
11 chain=block-ddos action=add-src-to-address-list address-list=ddoser address-list-timeout=10m log=no log-prefix=""
12 chain=input action=accept protocol=tcp dst-port=990 log=no log-prefix=""
13 chain=input action=accept protocol=tcp dst-port=989 log=no log-prefix=""
14 chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=47 log=no log-prefix=""
15 chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=140 log=no log-prefix=""
16 chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=1234 log=no log-prefix=""
17 chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=1236 log=no log-prefix=""
18 chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=21 log=no log-prefix=""
19 ;;; Make exceptions for DNS
chain=DNS_DDoS action=accept protocol=tcp src-address-list=DNS_Accept port=53 log=no log-prefix=""
20 ;;; Make exceptions for DNS
chain=DNS_DDoS action=accept protocol=udp src-address-list=DNS_Accept port=53 log=no log-prefix=""
21 ;;; Drop DNS_DDoS Offenders
chain=DNS_DDoS action=drop src-address-list=DNS_DDoS log=no log-prefix=""
22 ;;; Return from DNS_DDoS Chain
chain=DNS_DDoS action=return log=no log-prefix=""
23 ;;; default configuration
chain=input action=drop in-interface=ether1-gateway log=no log-prefix=""
24 ;;; default configuration
chain=forward action=drop connection-state=invalid log=no log-prefix=""
25 chain=input action=accept protocol=tcp dst-port=20 log=no log-prefix=""
26 ;;; Jump to DNS_DDoS Chain
chain=input action=jump jump-target=DNS_DDoS log=no log-prefix=""
27 X ;;; drop invalid connections
chain=forward action=drop log=no log-prefix=""
And this is the NAT
chain=srcnat action=masquerade out-interface=ether1-gateway log=no log-prefix=""
1 ;;; macchina_giuseppe
chain=dstnat action=dst-nat to-addresses=10.1.0.203 to-ports=22 protocol=tcp in-interface=ether1-gateway dst-port=1234 log=no log-prefix=""
2 ;;; raspberry
chain=dstnat action=dst-nat to-addresses=10.1.0.18 to-ports=22 protocol=tcp in-interface=ether1-gateway dst-port=1236 log=no log-prefix=""
3 chain=dstnat action=dst-nat to-addresses=10.1.0.100 to-ports=17700-17704 protocol=tcp dst-port=17700-17704 log=no log-prefix=""
4 chain=dstnat action=dst-nat to-addresses=10.1.0.99 to-ports=4299 protocol=tcp dst-port=4299 log=no log-prefix=""
5 chain=dstnat action=dst-nat to-addresses=10.1.0.99 to-ports=47 protocol=tcp in-interface=ether1-gateway dst-port=47 log=no log-prefix=""
6 chain=dstnat action=dst-nat to-addresses=10.1.0.99 protocol=tcp dst-address-type=local in-interface=ether1-gateway dst-port=21 log=no log-prefix=""
7 X chain=dstnat action=dst-nat to-addresses=10.1.0.99 to-ports=20 protocol=tcp in-interface=ether1-gateway dst-port=20 log=no log-prefix=""
8 chain=dstnat action=dst-nat to-addresses=10.1.0.99 to-ports=1024-65535 protocol=tcp dst-address-type=local dst-port=1024-65535 log=no log-prefix=""
9 X ;;; ex_giuseppe
chain=dstnat action=dst-nat to-addresses=10.1.0.202 protocol=tcp dst-port=1203 log=no log-prefix=""
