Example:
Client device (172.16.0.2/24) → (172.16.0.1/24) Mikrotik router without nat (192.168.0.2/24) → (192.168.0.1/24) Mikrotik router with NAT (Any globally routed address) → Internet
on client device default router is 172.16.0.1
on Mikrotik rouer without nat default router is 192.168.0.1
Is it possible to make a Mikrotik router with NAT to nat client’s device subnet (172.16.0.0/24) to the internet
FreeBSD PF can do this. Does Mikrotik able?
All routing if fine. Nat rules present.
I can make nat of 192.168.0.0/24 subnet from my example on Mikrotik router with nat easily. How to do this for 172.16.0.0/24?
Yes, you just need the correct routing & NAT rules in place.
Assuming ‘Mikrotik router without nat’ has a default route to 192.168.0.1, then on ‘Mikrotik router with NAT’ you need a static route for 172.16.0.0/24 to 192.168.0.2 and a suitable NAT rule, the one in Mikrotik default configuration applies NAT to all forward traffic leaving via the WAN interface.
should be able to properly NAT anything going out via WAN interface regardless the src-address.
If you want to get some concrete advice, post text export of main router’s configuration (execute /export hide-sensitive file=anynameyouwish in terminal, fetch resulting file, open it in text editor, obfuscate any remaining sensitive information such as public IP address or serial number, and copy-paste result inside [__code] [/code] environment).
