Is it possible to create a NAT pool on a MikroTik? I see where you can NAT 1:1 or masquerade. But i’ve got a /29 carved out for a NAT pool I want to be able to use all the addresses for nat. What’s the best way to go about doing that?
There are some script, if you search on forum, for create automatically the rules based on number of public IPs, number of NATted private IPs, port for IP, etc.
