NAT Port forwarding conflicts with Firewall (Default config)
I’ve read dozens of topics about configuring port forwarding, but nothing helped. I have Mikrotik rb751u-2hnd with default configuration.
WAN network 192.168.1.0/24 is connected to the ether1.
Local network is 192.168.88.0/24.
I want to get access to 22 port of the local machine 192.168.88.250 from the WAN.
Firewall filters:
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 2    ;;; defconf: accept established,related
      chain=input action=accept connection-state=established,related
 3    ;;; defconf: drop all from WAN
      chain=input action=drop in-interface=ether1
 4    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
 5    ;;; defconf: accept established,related
      chain=forward action=accept connection-state=established,related
 6    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
 7    ;;; defconf:  drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1
Nat rules:
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface=ether1
 1    ;;; SSH Port Forwarding to Raspberry Pi
      chain=dstnat action=dst-nat to-addresses=192.168.88.250 to-ports=22 protocol=tcp in-interface=ether1 dst-port=22 log=yes log-prefix="nat_d"
And this config doesn’t work. The problem is in #7 Filter (“drop all from WAN not DSTNATed”). After disabling it I can access to my local network from WAN.
Or I can just add this rule before “drop all from WAN not DSTNATed”:
 7    ;;; Hack rule
      chain=forward action=accept protocol=tcp in-interface=ether1 dst-port=22 log=no
Moreover, with such rule I can even delete NAT Forwarding rule and 22 port will still be reachable.
But if I edit it this way (in according with logic of #7 Filter (“drop all from WAN not DSTNATed”)):
 7    ;;; Hack rule
      chain=forward action=accept connection-nat-state=dstnat protocol=tcp in-interface=ether1 dst-port=22 log=no
Then the access is lost again…
It seems like NAT doesn’t mark Port Forwarding rule connection state as dstnat and it is blocked by #7 Filter (“drop all from WAN not DSTNATed”). Although I can see how packets count changes for the NAT Forwarding rule while attempting to connect via SSH.
Thanks in advance.
Same issue here, configured v6.39.1 through WebFig. Port forward did not work. Is it a known bug?
