Whole day I’m trying to forward a port to specific IP address in my internal network. I tried everything, including router reset and start over, but no result.
I’m attaching my current config, I hope somebody helps.
[admin@MikroTik] > /export hide-sensitive
# 2024-03-12 17:58:00 by RouterOS 7.13.5
# software id = E9JX-26SU
# model = RB5009UG+S+
# serial number = HF70963S8VZ
add admin-mac=78:9A:18:8A:20:9D auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.240.10-192.168.240.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
/ipv6 settings
set disable-ipv6=yes forward=no
add interface=sfp-sfpplus1 list=WAN
add address=192.168.240.1/24 comment=defconf interface=bridge network=192.168.240.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1
add add-default-route=no interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.240.250 client-id=ff:d2:e5:ab:65:0:2:0:0:ab:11:3d:7e:8a:9b:4c:a8:db:12 mac-address=04:32:01:9F:30:EE server=defconf
add address=192.168.240.251 mac-address=38:68:DD:85:14:F1 server=defconf
add address=192.168.240.0/24 comment=defconf dns-server=192.168.240.1 gateway=192.168.240.1
set allow-remote-requests=yes
/ip firewall address-list
add address=xx.xx.xx.xx list=admin_access
add action=accept chain=input src-address-list=admin_access
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=2222 protocol=tcp to-addresses=192.168.240.250 to-ports=22
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10 vrf-interface=sfp-sfpplus1
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10 vrf-interface=ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.240.0/24,xx.xx.xx.xx/32
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Sofia
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Nah, this omission only makes DST-NAT rule more greedy. It doesn't make it non-working. Would it be useful to include this addition? Depends if @OP needs to use NAT-ed port from inside LAN or not.
Do you mean, knowing the actual traffic flow requirements and perhaps a network diagram would help… gee… where have I heard that before? Certainly not in th non-existent First Post Process LOL.
Sorry, I wrote the post in a hurry at the end of the working hours.
I’ll describe my setup more detailed now, although without the required diagram, as I am typing on my phone ATM.
I have a Linux server behind my router, which job doesn’t concern us at the moment. I want to access this server from WAN to SSH, from certain IP addresses.
I had the same config tested on my other router, worked without any problems. I compared both routers’ configs, but couldn’t see where the problem was. I hope somebody will open my eyes for a stupid typo somewhere, or I’ve messed up a rule that I cannot see…
Yes, I have two ISPs, one is for backup.
There are ipv6 tables because this is the default config. I didn’t know what else to do at 5 p.m. so I reset the router with default configuration to see if this will fix my problem. Well, it didn’t.
Edit: before you ask me, yes, I’ve allowed ssh on the server.
Other than adding in-interface-list=LAN on the dstnat rule for completeness, there seems to be no reason at all for not reaching the server from the outside.
Are you sure you have a publicly reachable IP address??
Are you sure the server doesnt have its own firewall settings ( like if on a PC ).
I test it from another IP (I have two routers with two independent ISPs)
Both have a static IP address, public too. I can access the MikroTik with winbox, so that works.
I can see a connection when I try to connect from the other ISP, but Putty keeps denying.
Yes, the server has firewall, but as I said, I’ve enabled ssh from anywhere, so that shouldn’t be the problem. I can access it via ssh from LAN. I even made an IPsec tunnel between both routers and could access the server through it (that is before I reset with default config).
Just for information, the server is a brand new Lenovo ThinkSystem SR630 v2. I’m starting to wonder if it has some setting that bugs the whole thing.
Accessing the server from your other WAN connection is of course going to be problematic…
Think of the logic… You come in WAN2 ( not the primary WAN ) lets say you reach the server, the response will go out WAN1 the primary WAN.
The return will be coming from a different source address ( not the original destination address ) and thus will be rejected.
Please use your truly separate cellular connection to test, or perhaps ask a friend to test from their internet connection.
Im assuming that you simply want to use the main WAN all the time and WAN2 is purely a backup, in which case nothing special need be done.
If you want to access any server on WAN2 while WAN1 is still up then you need to do some work!
By the way, accessing winbox from the internet directly is a terrible idea.
No, you got me wrong. I am trying to access from entirely separate router with entirely separate ISP. Like if I’m trying to access my office from my home.
I have restricted access with winbox only to my own IP addresses
ok, I tried again, made a new configuration of the router from scratch. Again the same problem.
What I have found until now:
I connected the server i am trying to access via SSH to my other router (Router 2). I immediately succeeded to connect via SSH with the same port forwarding rule like in Router 1.
I tried switching to my second ISP (ISP 2) on my problematic router, and again connection is refused.
Every time I try to connect via SSH, no matter if from another router, or my cellphone mobile network, I can see the connection established in the Firewall connections, I can also see packets in the dst-nat rule of the port, but no matter all of that, I cannot access.
I tried with adding 1.1.1.1 to DNS servers, allowed remote requests, added in interface list WAN… again no result.
Called my ISP (ISP 1). They assured me that I am receiving a fully transparent service.
Sorry but your explanations are more confusing then clarifying.
I have no clue at all what you are doing or have attempted and I am getting tired of waiting for decent information.
Let see if we can make sense of it.
What make is router 2? ( assuming its in a separate location in the house and gets its feed from ISP2 and its not connected to the network fed by Router 1 )
So from PC behind Router 2 and ISP2 you can reach the SSH server behind R1 which is connected to ISP1?
So from behind Router 1, assuming a differenent PC, and ISP1 you cannot reach the SSH server on the SAME LAN?
