NAT question
I got a question.
The following configuration i have:
Basic WAN IP 100.100.100.100
Basic Firewalls setup (From quick setup)
A LAN subnet with a bridge: 10.10.10.0/24
A server with the IP: 10.10.10.100/24
The server 10.10.10.100 is sending SMTP traffic to port 25 to IP 100.100.100.100 from within the network.
I created a DST-NT with the config:
/ip firewall nat add chain=dstnat action=dst-nat dst-address=100.100.100.100 src-address=10.10.10.100 dst-port=25 to-addresses=10.10.10.100 protocol=tcp
But this is not working.
In testing everything including sending traffic from within the lan 10.10.10.0/24 to the ip 100.100.100.100 but it is not sending the traffic to 10.10.10.100 on port 25.
What am i doing wrong?
Shirenzo
hello shirenzo,
you don’t need that src-addr.
and specify which interface should listen for the incoming traffic to be translated.
