Hi, first of all sorry if my english is not good enough, i’m a spanish speaker.
Well, i’m new with RouterOS and i have the following issue: before buying a hEX S router i was running my homelab server with pfSense in wich i have NAT forwards, it was connected to a tplink consumer grade router with DMZ.
I buy this hEX router to learn a little bit more and to get rid of that low performance tplink router.
My current setup is a DMZ in the hex that points to pfSense. I’ve also made a masquerade rule from LAN to pfSense IP.
If i try to go into my domain from inside pfSense network (also in the hex lan) it redirects into RouterOS webfig page. But from the outside it works perfectly.
Before you ask, i’m tired of search info about this issue, this is my last resource.
Thanks!
