NAT Ros 3.*
Hi
I have a problem after installing a new router 433 AH the nat rules does’nt work. I used to have a router 532 with Ros 2.9.51 and everything worked well. What I’m doing is to nat all the port 25 traffic on our network to our local mailserver.
chain=dstnat dst-port=25 protocol=tcp action=dst-nat to-addresses=10.1.152.3 to-ports=25
In Ros 3.* it does’nt work at all. can someone tell what I’m doing wrong 'cause I went through ros 3.6 up to Ros 3.14.
maybe you have some other rule that conflicts with this one? rule looks fine to me
