I can set up a permanent uplink to my host
for all downlink connections be the same session
example:
PC1 Card NIC IP address (DHCP)
PC2 Card NIC IP address (DHCP) PC1 and PC2 Go to the same IP address 192.168.9.1:3004
I created a NAT Route High all conection to the same destination
192.168.9.1:3004 sent to the IP 10.1.21.29:2002
And we not problem with that except for one situation we try Conect sen 2 data for the PC at the same time one of the PC not connecting.
I need send data for the two pc’s at the same time.
- Suggestion:
It possible to establish a permanent connection to the host.
I can help
thanks
David
