NAT rule / port forwarding question
Got a fairly simple (double) NAT question (I think):
My setup:
https://ibb.co/sChnP46
I have a Mikrotik Hap AC2 connected to my ISP Modem/Router (not in bridge mode).
The MT gets static IP 192.168.0.4 on the ISP Router.
A webserver is connected to the MT, and gets static IP 10.0.1.5
I connect with my laptop to my ISP Router (Wifi is faster)
I would like to create a webhook to connect to my server.
So far I’ve created:
  • a port forward on my ISP router for port 8281 to point to 192.168.0.4 with port-forward 8581
  • a NAT rule to connect to the webserver via Dynamic DNS (myusername.no-ip.org:8581) and this works perfectly as it should.
Now I also would like to connect to my webserver locally by entering 192.168.0.4:8581 but so far I can’t get it to work.
Could anybody please point me in the right direction on how to proceed?
Thank you very much
FYI: My webserver is in a VLAN20
Below is my firewall config:
# feb/14/2022 09:22:27 by RouterOS 6.47.10
# software id = XJIR-23KF
# model = RBD52G-5HacD2HnD
# serial number = E5780FA00097
/ip firewall address-list
add address=192.168.0.4 list=WAN
add address=192.168.0.0/24 list=LAN
add address=10.0.2.20-10.0.2.50 list="Guest users"
add address=10.0.1.20-10.0.1.50 list="IoT devices"
add address=10.0.0.0-10.0.0.50 list="Main devices"
add action=drop chain=forward comment="Drop all from IOT to MAIN" dst-address=\
    10.0.0.0/24 src-address=10.0.1.0/24
add action=drop chain=input comment="Block guest - local ports" dst-address=192.168.0.4 \
    dst-port=80,21,22,23,8291 protocol=tcp src-address-list="Guest users"
add action=drop chain=input comment="Block guest - LAN" dst-address=192.168.88.0/24 \
add action=masquerade chain=srcnat dst-address=10.0.1.0/24 src-address=10.0.1.0/24
add action=masquerade chain=srcnat out-interface=ether1-WAN
add action=dst-nat chain=dstnat comment=Homebridge dst-address=192.168.0.4 dst-port=\
    8581 in-interface=ether1-WAN protocol=tcp to-addresses=10.0.1.5 to-ports=8581
[admin@MikroTik] >
Yes, check out this article and you will figure out what needs to be done, but more importantly WHY!
https://forum.mikrotik.com/viewtopic.php?t=179343
After looking at your config, you already have the required hairpin nat rule so it must be something else…
Read the article and the review your rule structure for this one… it needs to be fixed and the WHY above will tell you what needs to change.
Hint: your destination nat rule is not in the right format for any of the two options (its a combo of both that doesnt work):
a. a dynamic WANIP for hairpin NAT
b. a static WANIP in general (which needs no change for hairpin nat).
Also, to make any further assessments will need to see the complete config.
Thanks a LOT for this help, it worked perfectly !!
