Greetings
I must deal with one problem, i can’t handle.
Problem… I have two routers - Router 1 and router 2.
I setup IPSec between routers using http://gregsowell.com/?p=787 materials
But I created new networks on different ports.
What I must and how I must do, to access between those networks?
configuration Router 1
add action=accept chain=srcnat comment="IPSec" \
disabled=no dst-address=192.168.0.0/16 src-address=192.168.2.0/24
/ip ipsec peer
add address=1.1.1.1/32 auth-method=pre-shared-key dh-group=modp1024 \
disabled=no dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=3des \
exchange-mode=main generate-policy=no hash-algorithm=md5 lifebytes=0 \
lifetime=1d my-id-user-fqdn="" nat-traversal=yes port=500 proposal-check=\
obey secret="passwd" send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=192.168.1.0/24 dst-port=any \
ipsec-protocols=esp level=require priority=0 proposal=default protocol=\
all sa-dst-address=1.1.1.1 sa-src-address=2.2.2.2 \
src-address=192.168.2.0/24 src-port=any tunnel=yes
configuration Router2
add action=accept chain=srcnat comment=\
"IPSec" disabled=no dst-address=\
192.168.0.0/16 src-address=192.168.1.0/24
/ip ipsec peer
add address=2.2.2.2/32 auth-method=pre-shared-key dh-group=modp1024 \
/ip ipsec policy
add action=encrypt disabled=no dst-address=192.168.2.0/24 dst-port=any \
all sa-dst-address=2.2.2.2 sa-src-address=1.1.1.1 \
src-address=192.168.1.0/24 src-port=any tunnel=yes
I want to from 192.168.2.0/24; 192.168.102.0/24 Router 2 access Router 1 192.168.1.0/24; 192.168.100.0/24; 192.168.101.0/24 in both ways. How to deal with that?
