nat to ip from pppoe-out
i have a microtick attached to a internet line in ether1 and all users in network use that as their gateway.
every setting was established by mikrotik default script
now i want to use the second internet access at ether10 with valid ip address and use that address for connection to my internal server
the connection was successful and now i can see the microtik router from the outside with ip
i used this nat :
/ip firewall nat add chain=dstnat action=dst-nat dst-address=85.133.86.8 dst-port=22 to-addresses=172.22.66.10 protocol=tcp
but is not working
and i dont know why
because that server still go out from 1st wan and the remote device do not see the reply because coming from another IP
In short, the problem is elsewhere.
/export hide-sensitive file=anynameyouwish.
My guess is that IP routes are the issue, and is what I think rextended was alluding to.
I specify the global ip as the src-address not the dst-address and also the port on the to- and interface from which it is coming from:
chain=dstnat action=dst-nat to-addresses=10.0.2.2 to-ports=3306 protocol=tcp src-address=<global-ip> in-interface-list=INET dst-port=3306 log=no log-prefix=""
You can also enable log and then watch the log /log print follow-only.
Another thing I would do is use the sniffer to see where the packets are going:
/tool sniffer quick ip-address=10.0.2.2
