With pc a local network I can not through nat connect a mikrotik vpn on the removed address. From the mikrotik it is connected without problems.
P.S. Error 619
P.S. Error 619
Check that ‘pptp’ and ‘gre’ helpers are enabled on ‘ip firewall service-port’, if NAT is enabled on the router.
On a firewall openly all is transparent, without restrictions
If rotuer performs NAT check that particular NAT helpers are enabled.
If router does not perform NAT, than problem is somewhere else (if router does not have any firewall restrictions).
You can try to connect client direclty (before the router), then check how it wokrs.
Without a mikrotik works.
palam, do you read sergejs suggestions? please read them again, and enable GRE nat helpers in /ip firewall service-port
What is nat helpers?
NAT helpers allows to maintain multiple sessions over the router perfoming NAT.
In your case ‘pptp’ and ‘gre’ helpers required.
вот блин ничего не пойму…
Give on another I shall set a question.
v vashem routere napishite “ip firewall service-port” i togda ENTER. potom PRINT. smotrite chto tam napisano i napishite sdes.
фу хоть ктото по русски понимает.
сек
я по другому задам вопрос. (пользовался переводчиком т.к. англиский не очень хорошо знаю).
проблема вот в чем.
есть сеть с ип 193.239.. и внутреними адресами 192.168.. (в качестве шлюза микротик) и есть ип 85.223.. в качестве шлюза фри. я делаю подключение из сети 192.168.. на ип 85.223.. и пишет эту ошибку.
Vam nuzno vkljucitj ‘gre’ i 'pptp v
‘gre’ i ‘pptp’.
Eti stuki pomogajut rabotatj PPTP cerez NAT,
NAT meshaet rabote PPTP tunelej,
eti helperi neobhodimi na MikroTik routere (NAT proishodit na nem sudja po adresam).
Officialnij jazik foruma anglijskij, poetomu zelatelno ispolzovatj ego.
I’m sorry for the unofficial language post in this forum ![]()
Thanks, all ок
i have similar problem
what is solution
i enable gre and pptp
what is next
please eng.
bye
the only solution was to enable gre and pptp in the service ports menu
ok, he connect but new problem arive
when I create on my pc game server, he can’t find them!
i create ppp-secrets-add-name- what local address and remote address i must define in options?
when i use blank then vpn connection don’t work, when i put some address then work but no connection in game.
you will have to use EoIP in this case (if you like to do lanparty over a tunnel)
