I was pointed to the RB750GL to solve a network problem. Since the board is not that expensive, I just ordered it not knowing that it is a rather complex thing to set up.
So, before I spend too much time with trial and error, I would like to ask if the following is doable with the board:
Two networks (192.168.0.0/24 and 10.0.0.0/24) within the boundries of a factory are to be connected so that an OPC server in the first network (192.168.0.10) can communicate with a PLC in the second network (10.0.0.10) using an address from the range of the first network, say 192.168.0.11.
If so, is this something I can set up using the web interface of the board or do I have to get used to the console.
Any help appreciated
Florian
