NAT
If I have one LAN interface and 2 gateways. Can I have 2 IP addresses on the LAN interface and to do nat (masquerade) and load balancing.
If I have the following config will it work:
[admin@X] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.2/24 192.168.1.0 192.168.1.255 DSL
1 192.168.2.2/24 192.168.2.0 192.168.2.255 DSL
2 172.16.1.1/30 172.16.1.0 172.16.1.3 Inside
[admin@X] > ip firewall src-nat print
0 src-address=10.0.0.0/8 out-interface=DSL action=masquerade
[admin@X] > ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected, C - connect, S - static, r - rip, o - ospf, b - bgp
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 192.168.1.1 1 DSL
---------------- r 192.168.2.1 DSL
1 S 10.0.0.0/8 r 172.16.1.2 1 Inside
Let me see did I understood…
You have to dsl lines for internet and you have one lan interface to your Local network?
You want to use two subnets on Local network, so one will go through one dsl line and another one will go through another dsl line?
If I read your post right, it looks like you’re describing what I just got working this weekend. Look at this thread and see if it answer your question:
http://forum.mikrotik.com/t/policy-based-routing/4850/1
Mezlo
I have
1 x FastEthernet with 2 IP addresses 192.168.1.2 and 192.168.2.2
I want to do NAT on this interface and to load balance between 2 default gateways 192.168.1.1 and 192.168.2.1 connected on the same LAN segment
When send traffic to 192.168.1.1 NAT with address 192.168.1.2
and when send traffic to 192.168.2.1 NAT with address 192.168.2.2
Does this work or I must do it like all other times (to try)
