native IPv6 with PPPoE
Hi!
Briefly:
how to configure RouterOS v5.11 to use it for
dual IPv4 / IPv6 ADSL connection with PPPoE
and stateful address autoconfiguration ?
I have RB750 router with RouterOS v5.11 .
My ISP has dual-stack with native IPv6 on test-account.
This works perfectly with D-Link DIR-600/E router.
PC with Linux Mint gets the IPv6 address, default router,
DNS servers and I can reach IPv6 and IPv4 hosts.
I am using Dibbler client.
On my Mikrotik router I am getting IPv6 prefix using DHCPv6 client.
So far so good,
but until now I did not configure other settings successfully
to get needed network configuration using Dibbler on the host.
Can someone please explain me next steps on RouterOS
to make it work as DHCPv6 server for stateful IPv6 address
autoconfiguration of the hosts in LAN.
Thanks!
Statefull address configuration is not supported. You can add manually IPv6 address from the pool and set advertise=yes to enable stateless auto configuration.
Sorry, but this is not precisely enough for me, I am beginner.
As I wrote, on my Mikrotik router I am getting IPv6 prefix using DHCPv6 client.
Do I need to set up the IPv6 address from the pool to the router interface
where the LAN clients are connected ?
What should I configure on the hosts (clients) ?
Can I use or not the DHCPv6-server on Mikrotik ?
Please take a few minutes and describe me the next steps
with little bit more info.
Thank you very much!
