Hi team,
I ran into an issue that I am apparently not the only one to have.
On one site, I am currently migrating from a Cisco edge router to a MT RB3011, v7.5 stable.
eth4+5 bundled as a LAG to a switch, with a trunk on top of it (several tagged vlans, e.g. vl100 (transit VLAN to the “inside” firewall); vlan 2 (Management)…). Traffi from/to these vlans is working perfectly. The tricky part is that I also have a legacy VLAN1 (default vlan on Cisco) which cannot be decommissioned yet due to a technical limitation.
I know it’s a bad idea to use VLAN1 (as a default VLAN but also as a rule of thumb), and it will eventually be removed a few weeks after the migration (Q1 2023 at the latest). In the meantime, I must find a way to route this traffic from VLAN1 as for the other VLANS. I also have to use the same physical cable as there are no additional ones available as the racks are in different rooms
In Cisco language, what I want is just a “native vlan 1” on the trunk. I’ve tried to configure the switchport as vlan-mode=fallback, vlan-header=add-if-missing and Default-vlan-id=1 but it cuts me off (also for the tagged vlans).
When I leave the default settings (vlan-mode=disabled, vlan-header=leave-as-is and Default-vlan-id= not set), I see packets with VLANiD=1 coming into the interface eth4 (LLDP and 802.2 traffic) but no actual L3 payload (i.e. nothing from the source IP I am trying to ping from). Tagged vlans are working fine in this case, but not my vlan 1.
More instructive is that with vers7 the sensitive command is no longer required.
what is good to say is
.please post full config /export (minus serial number of router and any public WANIP info)
I think @rextended's point was that the opposite of show-sensitive is hide-sensitive. show-sensitive=no is a syntax error.
hide-sensitive is the default in v7, but it still shows the SN (which is the "key" to cloud based config backups, if I understood one of @rextended's previous posts).
So you still need to look for information you feel is private. I don't know if the license key "software id" is sensitive, but I always remove it when I post configs. For example:
Thanks for your help, guys. Yes, the show-sensitive parameter was already set to hide sensitive data a while ago. I don’t remember if the switch was made between 6.x and 7.x release, but it quite likely. I think it was around that time.
I stripped the really unrelated lines of config (LCD screen, NTP, scripts &scheduling, disabled FW rules… ) for better readability for those who will run into the same issue and read this post in the future.
The config is quite simple as I’m still in the staging phase. Here we go:
oct/05/2022 01:12:48 by RouterOS 7.5
# software id = X
# model = RouterBOARD 3011UiAS
# serial number = XXX
add name=loopback0
set [ find default-name=ether1 ] mac-address=08:55:31:D2:37:07 name=eth1-WAN
set [ find default-name=ether4 ] mac-address=08:55:31:D2:37:0A name="eth4 - Transit LAG 10"
set [ find default-name=ether5 ] mac-address=08:55:31:D2:37:0B name="eth5 - Transit LAG 10"
set [ find default-name=ether9 ] mac-address=08:55:31:D2:37:0A name="eth9 - DMZ"
set [ find default-name=ether10 ] mac-address=08:55:31:D2:37:11 name="eth10 - MGT" poe-out=off
/interface vlan
add interface="eth9 - DMZ" name="vlan90 - DMZ" vlan-id=90
add interface=eth1-WAN loop-protect=off name="vlan2900 - ISP WAN" vlan-id=2900
/interface bonding
add arp-ip-targets=0.0.0.0 lacp-rate=1sec mode=802.3ad name=LAG10 slaves="eth4 - Transit LAG 10,eth5 - Transit LAG 10"
/interface vlan
add interface=LAG10 name="vlan1 - Legacy" vlan-id=1 // => This is my vlan that I don't get any reply from
add interface=LAG10 name="vlan2 - MGT" vlan-id=2
add disabled=yes interface=LAG10 name="vlan10 - SERVER-PRIVATE" vlan-id=10
add disabled=yes interface=LAG10 name="vlan15 - SERVER-PUBLIC" vlan-id=15
add disabled=yes interface=LAG10 name="vlan20 - WORKSTATIONS" vlan-id=20
add disabled=yes interface=LAG10 name="vlan30 - IPTEL" vlan-id=30
add disabled=yes interface=LAG10 name="vlan40 - PRINTERS" vlan-id=40
add disabled=yes interface=LAG10 name="vlan50 - LAB" vlan-id=50
add disabled=yes interface=LAG10 name="vlan60 - WLAN" vlan-id=60
add interface=LAG10 name="vlan100 - TRANSIT" vlan-id=100 //=> Working OK
set 4 default-vlan-id=1 vlan-header=add-if-missing. // => this is what I tried and that curt me off. and when I remove it, VLAN100 traffic works correctly, but still no traffic on vlan1
add comment=defconf name=WAN
add comment=TRANSIT name=TRANSIT
add comment="Out-of-Band Management" name=MGT
/interface bridge filter
add action=set-priority chain=output disabled=yes dst-port=67 ip-protocol=udp log=yes log-prefix="Set CoS6 on DHCP request" mac-protocol=ip new-priority=6 out-interface=*D passthrough=yes
add bridge=*E ingress-filtering=no interface=*D
set enabled=yes
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192 rp-filter=loose
add comment="WAN" interface=eth1-WAN list=WAN
add comment="Management Interface" interface="eth10 - MGT" list=MGT
add comment=Transit interface=LAG10 list=TRANSIT
add comment="WAN" interface="vlan2900 - ISP WAN" list=WAN
add address=172.16.2.10/24 comment=Management interface="vlan2 - MGT" network=172.16.2.0
add address=172.16.100.2/24 comment="Transit vlan 100" interface="vlan100 - TRANSIT" network=172.16.100.0
add address=172.16.0.1 interface=loopback0 network=172.16.0.1
add address=172.16.90.1/24 comment="Direct Internet Access DMZ" interface="eth9 - DMZ" network=172.16.90.0
add address=192.168.127.254/23 comment="Vlan1 - Legacy" interface="vlan1 - Legacy" network=192.168.126.0 //=> This is the IP I don't get any reply from
/ip firewall address-list
add address=172.20.20.0/24 disabled=yes list=NAT
add address=172.20.100.0/24 list=NAT
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=input comment="DROP INVALID PACKETS" connection-state=invalid
add action=accept chain=input comment="ACCEPT ESTABLISHED AND RELATED CONNECTIONS" connection-state=established,related
add action=accept chain=input comment=STAGING!!!!
add action=accept chain=forward comment=STAGING!!!!
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="CLEANUP RULE - DROP ALL PACKETS COMING FROM WAN (FWD CHAIN)" in-interface=pppoe-WAN log=yes
add action=masquerade chain=srcnat dst-address=!172.16.0.0/12 out-interface=pppoe-WAN src-address=192.168.126.0/23
add disabled=no distance=1 dst-address=172.16.0.0/16 gateway=172.16.100.1 pref-src="" routing-table=main suppress-hw-offload=no
There do not appear to be any valid bridge ports, are you using this purely as a router? If so, leave the switch settings at their default values and just attach the IP address to the bond interface:
the following refer to non-existant interfaces and can be removed:
add action=set-priority chain=output disabled=yes dst-port=67 ip-protocol=udp log=yes log-prefix=“Set CoS6 on DHCP request” mac-protocol=ip new-priority=6 out-interface=*D passthrough=yes
From the MAC addresses under /interface ethernet you have likely restored a .backup from a different Mikrotik - this clones the MAC addresses of the oroginal device which will cause issues if both are present on the same L2 network. You can reset the interface MAC addresses to fix this.
You are right regarding the bridge ports in my config. They aren’t used…yet! But I need those to setup a Loopback interface which in turn will be used for OSPF and GRE/IPsec tunnels, which will happen in the next couple of days. So I will be needing these bridge ports.
Absolutely! I indeed took a running config from another site as a good part of the config is similar. These devices will not see each other on L2, however you have a good point, I will clean this up immediately.
I can confirm, it works! thanks a lot for your hints, I would never have found the solution myself.
so, to sum up for others who might have a similar issue: the key is to configure an IP address directly on the interphace (physical ethX or LAG, if any) for the native VLAN, but NOT creating a VLAN 1 on the LAG or physical interface itself.
[quote=kennnnnnnneth post_id=960594 time=1664999667 user_id=184396]
Wow, thank you for reminding me why I don’t visit this forum very often <3
[/quote]
Is it because you can’t provide instructions without checking them first?
Now ken, syntax is important and making up sheite is really not a good plan. If you got called out for it, just admit and move on and do better next time.
This is not a coddling forum.
It is natural to feel defensive and uncomfortable when an honest mistake is pointed out in public.
The point is, try not to take comments as a personal attack.
Pointing out incorrect or bad advice is “standard operating procedure” in any technical forum I am aware of.
Many technical experts tend to be quite blunt and straight to the point, and probably tend more toward the “thinking” vs “feeling” personality types in the Myers & Briggs personality types.
I understand your advice was well intentioned, but we would be remiss for not correcting the error.
I often get schooled about my horrible advice, and its always a learning opportunity.
I didn’t even know what “Miao” meant until you pointed it out and I used DeepL to translate. I had assumed it was another form of Ciao, but it apparently is just “Meow”, i.e. “what a cat says”.
