Nearley dead RB433
I have the following problem, The router board beeps once then no more beeps. I have tried to see it via winbox and neighbour viewer No luck, Then I tried telnet and got this below. Is there a way I can recover this board?
Thanks in advance
Richard
RouterBOOT booter 2.29
RouterBoard 433
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
System halted.
Hi Richard,
I would just try the following two scenarios -
  1. test with a new power supply;
  2. check the capacitors on the board - if there is brown stuff on top or swollen, these need to be replaced.
Rgds,
Mark.
Hi Mark,
Electrolytics were OK tried a new power supply all OK. It fooled me by partley booting.
Many thanks
Richard
Hi Richard,
No sweat. Happened to me too.
Glad I could help.
Rgds,
Mark.
