Need a hand with moderate config
Greeting Programs!
I have been using Mikrotik routers for a few years now but haven't delved into the deep end until now. I know it can be a nightmare for a new user, but this is why we have places like this to turn to.
I currently have a hex-s at my home and a x86 RoS instance at my colo. I have an EoIP tunnel configured between the two and I can ping between them. I have not setup routing yet.
I tried do use ipsec with the tunnel but when i disable fastpath in order to use ipsec, the tunnel drops the connection and will not reconnect. My end goal here is to have a few computers at my home use the internet as its normally routed from my isp. I want to have another set routed through the tunnel to use the network at my colo. Not sure whats the best way to do that. I had though about using a vlan but any input is welcomed for this.
Also any idea as to why the tunnel drops out when checking off of fastpath?
Here is the current config from my colo.
feb/17/2019 09:50:59 by RouterOS 6.43.12
software id = P5DA-M6TF
set [ find default-name=ether1 ] mac-address=00:0C:29:EC:D5:93
/interface eoip
add local-address=192.254.69.163 mac-address=02:41:B4:08:00:D0 name=
eoip-tunnel-r1 remote-address=24.167.144.134 tunnel-id=5
/interface vlan
add interface=eoip-tunnel-r1 name=vlan1 vlan-id=50
add name=WAN
add name=LAN
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.202.2-192.168.202.80
add address-pool=dhcp disabled=no interface=vlan1 name=dhcp1
/ppp profile
add local-address=dhcp name=profile1 remote-address=dhcp
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface l2tp-server server
set default-profile=profile1 enabled=yes max-mru=1470 max-mtu=1470
add interface=ether1 list=WAN
add list=LAN
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2
add address=192.254.69.163/29 interface=ether1 network=192.254.69.160
add address=172.22.22.1/30 interface=eoip-tunnel-r1 network=172.22.22.0
add address=192.168.201.1/24 interface=ether1 network=192.168.201.0
/ip cloud
set update-time=no
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
set allow-remote-requests=yes servers=192.254.69.164
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input protocol=gre
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward ipsec-policy=out,ipsec
add action=accept chain=srcnat src-address=192.168.201.0/24
add distance=1 gateway=192.254.69.161
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/ipv6 address
add address=2607:5600:534::600/48 advertise=no interface=ether1
/ipv6 route
add distance=1 gateway=2607:5600:534::1
/ppp secret
add name=matt profile=profile1
/system clock
set time-zone-name=America/New_York
/system ntp client
set enabled=yes primary-ntp=129.6.15.28 secondary-ntp=129.6.15.29
/tool bandwidth-server
set enabled=no
/tool user-manager database
set db-path=user-managerAnd here is the config from the hex-s at my home
feb/17/2019 09:59:22 by RouterOS 6.42.7
software id = HIH6-FCRR
model = RB760iGS
serial number = 976C09D69279
add admin-mac=B8:69:F4:05:9B:95 auto-mac=no comment=defconf name=bridge
/interface eoip
add local-address=24.167.144.134 mac-address=02:3F:A1:30:4C:68 name=eoip-tunnel1 remote-address=192.254.69.163 tunnel-id=5
/interface vlan
add interface=bridge name=vlan1 vlan-id=51
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec proposal
add name=dhcp ranges=192.168.200.10-192.168.200.100
add name=dhcp_pool1 ranges=192.168.201.2-192.168.201.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=vlan1 name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge interface=ether1
add interface=sfp1 list=WAN
add address=192.168.200.1/24 comment=defconf interface=bridge network=192.168.200.0
add address=172.22.22.2/30 interface=eoip-tunnel1 network=172.22.22.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=sfp1 use-peer-dns=no use-peer-ntp=no
add address=192.168.200.0/24 comment=defconf gateway=192.168.200.1 netmask=24
/ip dns static
add address=192.168.200.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new
in-interface-list=WAN
add action=drop chain=input dst-port=53 in-interface=sfp1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=sfp1 protocol=tcp
add action=dst-nat chain=dstnat dst-port=5579 in-interface=sfp1 protocol=tcp to-addresses=192.168.200.201 to-ports=5579
add action=dst-nat chain=dstnat dst-port=32400 in-interface=sfp1 protocol=tcp to-addresses=192.168.200.222 to-ports=32400
add action=dst-nat chain=dstnat dst-port=40000 in-interface=sfp1 protocol=tcp to-addresses=192.168.200.75 to-ports=32400
add action=dst-nat chain=dstnat dst-port=5000 in-interface=sfp1 protocol=tcp to-addresses=192.168.200.222 to-ports=5000
add action=dst-nat chain=dstnat dst-port=6281 in-interface=sfp1 protocol=tcp to-addresses=192.168.200.222 to-ports=6281
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=
fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
/system ntp client
set enabled=yes primary-ntp=132.163.96.5 secondary-ntp=132.163.97.5
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
Anyone have any ideas?
