Hi every one ,
I’m using The Dude ,
I wanna make it monitor my local network, which contain wired clients and wireless clients .
here what is needed in the wired :
I wanna draw a switch map and show the wired links ,
I wanna every single switch to contain the clients who’re connected to ,
I used the "new map & and sumap " to show the Switches
I wanna the Switch’s Color to be Green if all clients are UP, and Orange if at least one client is Up
and red if all down ,
the Problem is the map turns red if only one completely down ,
maybe a pc is fully down it isn’t problem with me , if there at leas only one alive “up” the switch will be orange or green , with a simple look , i will be completely able to keep an eye on the whole network ..
I hope some one helps me with the right setting , thanx
