need a longer trial.
Our company has a very long enjoyed your products. And we never had any problems. But now I need your help. I’m not enough 24-hour testing period Mikrotik RouterOS 6.20. Is there a way to get the extension of the test period even be up to 30 days? We collect one system and can not understand will work or not, and can not throw to the wind $ 200. Will be installed on the VDS as a central node, but it is necessary to watch the handle if all is well, and 24 hours not enough. A few years buying only your routers mainly 951G-2Hnd in offices. But now can not do it without your help. Do you have the opportunity to give a longer trial?
Or daily reinstall and import config.
contact sales@mikrotik.com and explane your problem
You can try to use GNS3 to simulate the entire topology.
I understand your problem, that creating a real network can often take a few days, thus rendering the trial period insufficient, but with GNS3, you can create the entire topology in a few hours, tops. You can create as many VMs as you want, and try out as many different setups as you want, before you commit to a certain type of setup, buy a real router, and set it up accordingly.
(P.S. Version 6.20 has a problem with VMs though… use 6.19 for now…)
Is your problem solved?
Let us know please
