Need A proxy service provider
Dear Friends
I will be very please if an expert can recommend a proxy service provider .
l need it for a hotspot service l run to over come Geo location restriction.
it will not be for free
www.vip72.com
expensive stuff. but works great, and fast:
https://www.goldenfrog.com/vyprvpn/buy-personal-vpn-service
nice one i think it is not so expensive $19.99 per month
True VyprVPN is good and fast. But I’m only able to get it working at the host level(linux Ubuntu desktop)
Any suggestion on the best way to setup VyprVPN with a MikroTik device as the client?
Just adding myself as another user that would love to be able to use Vyprvpn with mikrotik without flashing the firmware to dd-wrt as their support suggests… Yuk
Please Mikrotik Guru’s come to the rescue and help us sort this. Either by Open VPN or by PPTP
This is a link that the support team at vypr sent me. (Note: this is a script to configure a DD-WRT box, so I only posted it so that you could see if there is enough info in there to configure the Mikrotik)
https://www.goldenfrog.com/support/vyprvpn/vpn-setup/dd-wrt/openvpn
…I have pasted the dd-wrt script that it refers to below.
This is the link to configure for Linux
https://www.goldenfrog.com/support/vyprvpn/vpn-setup/linux/openvpn
I have tried to import that cert and use it to create a new openvpn client but get a "Couldn’t add New Interface - no certificate found (6)‘’ error
Any sort of hint even on a direction to go on this would be great.
Regards
Sam
#!/bin/sh
USERNAME="Username"
PASSWORD="Password"
PROTOCOL="udp"
# Add - delete - edit servers between ##BB## and ##EE##
REMOTE_SERVERS="
##BB##
# NA - VPN
remote EnterVPNServerHere 1194
##EE##
#### Do not make modifications below this line ####
CA_CRT='-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----'
OPVPNENABLE=`nvram get openvpncl_enable | awk '$1 == "0" {print $1}'`
if [ "$OPVPNENABLE" != 0 ]; then
   nvram set openvpncl_enable=0
   nvram commit
fi
sleep 10
mkdir /tmp/vpn; cd /tmp/vpn
echo -e "$USERNAME\n$PASSWORD" > userpass.conf
echo "$CA_CRT" > ca.crt
echo "#!/bin/sh
iptables -t nat -I POSTROUTING -o tun0 -j MASQUERADE" > route-up.sh
echo "#!/bin/sh
iptables -t nat -D POSTROUTING -o tun0 -j MASQUERADE" > route-down.sh
chmod 644 ca.crt; chmod 600 userpass.conf; chmod 700 route-up.sh route-down.sh
sleep 10
echo "client
auth-user-pass /tmp/vpn/userpass.conf
management 127.0.0.1 5001
management-log-cache 50
dev tun0
proto $PROTOCOL
comp-lzo adaptive
fast-io
script-security 2
mtu-disc yes
verb 4
mute 5
cipher bf-cbc
auth sha1
tun-mtu 1500
resolv-retry infinite
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
log-append vpn.log
ca ca.crt
status-version 3
status status
daemon
$REMOTE_SERVERS" > vpn.conf
ln -s /tmp/vpn/vpn.log /tmp/vpn.log
ln -s /tmp/vpn/status /tmp/status
(killall openvpn; openvpn --config /tmp/vpn/vpn.conf --route-up /tmp/vpn/route-up.sh --down /tmp/vpn/route-down.sh) &
exit 0
