need a quick replay
can i use three different wireless mini pci carts with rb 433.
is it true that the router board have a damage if we put more than one wireless cart with rb 433
need answer quickly please
with thankssssssss
1 yes
2 no
but why there are three slots in the board ?
To use 3 cards. It won’t hurt it if you do.
if the cards are going to use much power, also consume more power. you can use 3 cards but you can use low power and remember: the motherboard has a limit of power that can give to mini-pci ports
is there a routerboard that i can use 2 cards( 5ghz) and one card(2.4ghz) with it ?
Yes. You can use RB411AR or RB411UAHR. Both have integrated 2.4Ghz radio and a miniPCI slot for another card which can be of the 5Ghz variety.
See http://www.routerboard.com for datasheets.
Rgds,
Mark.
You can use any board as long as it has multiple slots.
