Need a script for Nights and Weekends Access pls
Kudos to you all. Pls i need a script that can allow a group of users access to my network between 6pm friday and 6am monday only to work with the one i already have which allow access between 6pm and 6am daily and is working fine. Pls help!
Thanks for this but still have some problem in the following areas: Your example of simple queue uses static allthrough, in my case, i run hotspot which add simple queue dynamically using the user profile from the hotspot. How do i combine this with the static simple queue? Also from your example, the CAT1,2,3 you use, are they created in user profile? or how do i direct diffrent users to different queues?
Highhly appreciated.
sorry am not very good at dis, Still not getting it
can you be more detail particularly on the simple queues limiting access for a particular user base on time (days)? Like i said b4, the hotspot add those queues automatically and not me. or better still can i reach you via phone, direct chat? i need this to work as soon as possible. also if add the queue, how do i direct the user to that particular queue?
Regards
I will be really glad if you could make out time to help directly as you said. You can always reach me via onojahj@yahoo.com or onojahj@hotmail.com or better still we via phone: 2348055353151 and i will call you back.
