I need some advice regarding a PCC load balancing setup.
I’m using a MikroTik RB450Gx4 running RouterOS v7, with two ISPs that have different bandwidths:
ISP 1: 30 Mbps
ISP 2: 100 Mbps
I’m planning to use PCC (Per Connection Classifier) for load balancing.
Port 3 is connected to Access Point 1, and port 4 is connected to Access Point 2.
Each access point is limited to 50 Mbps bandwidth.
Could anyone recommend a good and stable PCC method (ratio, rules, or best practices) for this setup?
Any example configuration or suggestions would be greatly appreciated.
