I’m currently have multiple mikrotik setups configured and running, but I need to be able to have client’s use there Apple OSX buildin VPN client to connect to internal networks.
Could somebody share the config or point me to a setup/howto ?
I’m even willing to pay (paypal) somebody who helps getting this setup…
if you have a secure option like ipsec/l2tp you should use it, as pptp is insecure by design and by implementation (where i do not know how mt implemented it, i think it is poptop):
perhaps first try a ipsec/l2tp-connection against a openswan and after you have that working try it with a mikrotik-box. by that you eliminate errors on the osx-side.
