need answer for network config
rb450G has 3 WAN’s after it rb800 is a gateway for users.
can i create 3 pppoe conections from rb800 over 3 wans on rb450G??
Hi, routerOS has multiplink PPP client, but not multiLink PPP server (yet): http://wiki.mikrotik.com/wiki/Manual:MLPPP_over_single_and_multiple_links
You might try independent PPPoE then make ethernet-like tunnels (e.g. eoip) and then use interface bonding.
Cheers!
actually, eiop is redundant
this is scheme on rb450G has 3 wans with dhcp clients, from rb800 i need to create 3 pppoe sessions over 3 wans on rb450g respectively.
Can mikrotik do it?
sure. use VLANs and bridge them with WANs on RB450
thanks a lot.
