Need assistance trunking vlans between two 750gs
I need to simply extend several vlans to a 2nd 750g switch. In my setup, two or three ports on each switch will be configured for a single vlan.
I have tried several configurations, but am not getting it to work
Here is what I currently have configured on each switch:
Switch1:
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=1594 max-message-age=20s mtu=1500
name=VLAN106 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=vlan01 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=VLAN108 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=VLAN110 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=VLAN107 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:60:6B
master-port=none mtu=1500 name=ether1-gateway speed=1Gbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:60:6C
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=no bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:60:6D master-port=
none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:60:6E
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:60:6F
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether1-gateway l2mtu=1594 mtu=1500
name=vlan1 use-service-tag=no vlan-id=1
name=vlan106 use-service-tag=no vlan-id=106
name=vlan108 use-service-tag=no vlan-id=108
name=Vlan109 use-service-tag=no vlan-id=109
name=vlan110 use-service-tag=no vlan-id=110
add arp=enabled disabled=no interface=ether2 l2mtu=1594 mtu=1500 name=
Vlan109B use-service-tag=no vlan-id=109
add arp=enabled disabled=no interface=ether2 l2mtu=1594 mtu=1500 name=vlan1B
vlan106B use-service-tag=no vlan-id=106
name=vlan107 use-service-tag=no vlan-id=107
vlan107B use-service-tag=no vlan-id=107
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set [ find default=yes ] dns-name=“” hotspot-address=0.0.0.0 html-directory=
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=default rate-limit=“” smtp-server=0.0.0.0
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add address-pool=default-dhcp authoritative=after-2sec-delay bootp-support=
static disabled=no interface=ether2 lease-time=3d name=default
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=
ospf-in metric-bgp=auto metric-connected=20 metric-default=1
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 syslog-facility=daemon
syslog-severity=auto target=remote
/user group
set read name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,!ftp,!write,!policy” skin=default
set write name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,!ftp,!policy” skin=default
set full name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api” skin=default
add bridge=VLAN106 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan106 path-cost=10 point-to-point=auto priority=0x80
add bridge=vlan01 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan1 path-cost=10 point-to-point=auto priority=0x80
add bridge=VLAN108 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan108 path-cost=10 point-to-point=auto priority=0x80
interface=ether4 path-cost=10 point-to-point=auto priority=0x80
add bridge=VLAN107 disabled=no edge=auto external-fdb=auto horizon=none
interface=ether3 path-cost=10 point-to-point=auto priority=0x80
add bridge=VLAN110 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan110 path-cost=10 point-to-point=auto priority=0x80
interface=ether5 path-cost=10 point-to-point=auto priority=0x80
interface=vlan107 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:6A:E6:E9:3E:BB
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.197.10.3/16 disabled=no interface=ether3 network=10.197.0.0
add address=x.x.x.x/24 disabled=no interface=ether3 network=x.x.x.x
/ip dhcp-client
add add-default-route=yes comment=“default configuration”
default-route-distance=1 disabled=no interface=vlan106 use-peer-dns=yes
use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.88.0/24 comment=“default configuration” dhcp-option=“”
dns-server=192.168.88.1 gateway=192.168.88.1 ntp-server=“” wins-server=“”
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 servers=10.10.4.21
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment=“default configuration” disabled=no
protocol=icmp
connection-state=established disabled=no in-interface=ether1-gateway
connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment=“default configuration” disabled=no
add action=masquerade chain=srcnat comment=“default configuration” disabled=
yes out-interface=ether1-gateway to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set vlan1 disabled=yes
set vlan106 disabled=yes
set VLAN106 disabled=no
set vlan01 disabled=no
set VLAN108 disabled=no
set vlan108 disabled=yes
set Vlan109 disabled=yes
set vlan110 disabled=yes
set VLAN110 disabled=no
set Vlan109B disabled=yes
set vlan1B disabled=yes
set vlan106B disabled=yes
set vlan107 disabled=yes
set vlan107B disabled=yes
set VLAN107 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet address=10.10.0.0/16 disabled=no port=23
set ftp address=10.10.0.0/16 disabled=no port=21
set www address=“” disabled=no port=80
set ssh address=“” disabled=yes port=22
set www-ssl address=“” certificate=none disabled=yes port=443
set api address=“” disabled=yes port=8728
set winbox address=“” disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment=“default share” directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password=“” read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=VLAN106 type=internal
add disabled=no interface=ether1-gateway type=external
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-generators=“”
trap-target=“” trap-version=1
/system clock
set time-zone-name=America/Chicago
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
set [ find ] channel=0 disabled=no term=vt102
/system identity
set name=MikroTik
/system logging
set 0 action=memory disabled=no prefix=“” topics=info
set 1 action=memory disabled=no prefix=“” topics=error
set 2 action=memory disabled=no prefix=“” topics=warning
set 3 action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=24.124.0.251 secondary-ntp=
208.113.193.10
/system resource irq
set 0 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 starttls=no user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=ether2
add disabled=no interface=ether3
add disabled=no interface=ether4
add disabled=no interface=ether5
/tool mac-server mac-winbox
set [ find default=yes ] disabled=yes interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=1000KiB file-name=“” filter-ip-address=“” filter-ip-protocol=
“” filter-mac-address=“” filter-mac-protocol=“” filter-port=“”
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups=“” interim-update=0s
use-radius=no
Switch2:
name=Vlan1 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=Vlan106 priority=0x8000 protocol-mode=none transmit-hold-count=6
name=Vlan107 priority=0x8000 protocol-mode=none transmit-hold-count=6
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:07:21
master-port=none mtu=1500 name=ether1 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:07:22
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:07:23
master-port=none mtu=1500 name=ether3 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:07:24
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:C2:07:25
/interface vlan
add arp=enabled disabled=no interface=ether1 l2mtu=1594 mtu=1500 name=1
add arp=enabled disabled=no interface=ether1 l2mtu=1594 mtu=1500 name=106
add arp=enabled disabled=no interface=ether1 l2mtu=1594 mtu=1500 name=107
set switch1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=
default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=
default use-compression=default use-encryption=yes use-mpls=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
set default disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=
default
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-target=0.0.0.0
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=“”
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 syslog-facility=daemon
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
add bridge=Vlan106 disabled=no edge=auto external-fdb=auto horizon=none
interface=106 path-cost=10 point-to-point=auto priority=0x80
add bridge=Vlan1 disabled=no edge=auto external-fdb=auto horizon=none
interface=1 path-cost=10 point-to-point=auto priority=0x80
add bridge=Vlan107 disabled=no edge=auto external-fdb=auto horizon=none
interface=107 path-cost=10 point-to-point=auto priority=0x80
interface=ether2 path-cost=10 point-to-point=auto priority=0x80
no
set ether1 vlan-mode=disabled
set ether2 vlan-mode=disabled
set ether3 vlan-mode=disabled
set ether4 vlan-mode=disabled
set ether5 vlan-mode=disabled
set switch1_cpu vlan-mode=disabled
default enabled=no keepalive-timeout=60 mac-address=FE:BE:E0:A6:CF:F9
/ip accounting
add address=10.10.1.101/16 disabled=no interface=ether5 network=10.10.0.0
add address=x.x.x.x/24 disabled=no interface=ether2 network=x.x.x.x
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set 1 discover=no
set 106 discover=no
set 107 discover=no
set Vlan1 discover=yes
set Vlan106 discover=yes
set Vlan107 discover=yes
/ip proxy
0.0.0.0
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
/port firmware
/ppp aaa
/queue interface
set ether1 queue=ethernet-default
/radius incoming
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
/routing rip
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system console
add disabled=no term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
/system ntp client
set enabled=no mode=broadcast primary-ntp=10.10.1.1 secondary-ntp=208.75.88.4
set 0 cpu=auto
set 1 cpu=auto
0.0.0.0 user=“”
/system watchdog
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 user=“”
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames
filter-stream=yes interface=all memory-limit=10 memory-scroll=yes
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Please format properly so it’s legible-
[code2=ros][/code2]
My apologies, but I have no idea what you mean.
Just press Edit button on your previous message and mark the hole config
and then press the button Select a Syntax and select “Router OS”.
And then save the message.
Your message will then be properly formatted with colors and so on.
More easy to read your config on the forum.
Thanks… I thought it was a special export function I didn’t know about :slight_smile:
You may not include your own written text.
Just mark your config.
Failed to mention, P1 on switch 1 is uplink to main HP switch, P5 connects to P1 of 2nd switch.
Got it working by adding new vlan interfaces to current vlan bridges.
