Greetings. I am looking to do a VLAN / sandbox for my IP cameras. I followed The Network Berg videos as closely as possible to do a HW offloaded VLAN modified to my needs. I’ve used all of the stock firewall rules and added 4 FW/ 1 NAT rule to allow the BaseLAN access to VLAN10 and isolate the VLAN from the WAN.
I do realize the server PC should be attached to the managed switch but until I am comfortable with VLAN’ing my D-Link switches, this will suffice. I am planning the next stage of the net where I have 3 VLANs trunked to the switches and WiFi APs.
For the most part my code is working, but there is one particular rule that I am stuck on which is supposed to block VLAN10 from accessing BaseLAN. Also I am not sure about the Masquerade rule being used the way I did it, but it does work the way I want.
"*************** Drop anything from VLAN10 to LAN" dst-address=\
192.168.88.0/24 src-address=192.168.10.0/24
The above rule kills DHCP on VLAN10, but if I disable it, VLAN10 can ping BaseLAN which is undesirable.
Complete config:
# 2024-08-28 19:01:04 by RouterOS 7.15.3
# software id =
# model = RB960PGS
# serial number =
add admin-mac=**:**:**:**:**:** auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface vlan
add interface=bridge name=CamNet vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=88.xxx-dhcp ranges=192.168.88.10-192.168.88.254
add name=CamNET_pool1 ranges=192.168.10.10-192.168.10.100
add name=dhcp_pool3 ranges=192.168.88.2-192.168.88.254
add name=dhcp_pool4 ranges=192.168.10.2-192.168.10.254
add address-pool=88.xxx-dhcp comment="Base LAN Pool (VLAN1) " interface=\
bridge name=88.xxx_dhcp
add address-pool=dhcp_pool4 comment="Pool for testing CamNET (VLAN10)" \
interface=CamNet name=10.xxx_dhcp
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment="This interface to be used for VLAN10" interface=\
ether5 pvid=10
add bridge=bridge comment="Set ether1 set as Bridge SFP1 to WAN" interface=\
ether1
/ipv6 settings
set disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=bridge tagged=bridge untagged=ether5 vlan-ids=10
add comment=defconf interface=sfp1 list=WAN
192.168.88.0
add address=192.168.10.1/24 interface=CamNet network=192.168.10.0
/ip dhcp-client
add address=192.168.10.0/24 comment="CamNET DHCP" dns-server=192.168.88.1 \
gateway=192.168.10.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
"*************** Allow VLAN1 to access VLAN10" dst-address=\
192.168.10.0/24 src-address=192.168.88.0/24
"*************** Drop anything from VLAN10 to WAN" \
out-interface-list=WAN src-address=192.168.10.0/24
"*************** Drop anything from WAN to VLAN10" dst-address=\
192.168.10.0/24 in-interface-list=WAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
out-interface-list=WAN src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="Allows VLAN1 onto VLAN10" \
dst-address=192.168.10.0/24 dst-address-list="" ipsec-policy=out,none \
src-address=192.168.88.0/24 src-address-list=""
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip hotspot profile
/ip service
set telnet disabled=yes
set www address=192.168.88.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=America/Vancouver
/system note
set show-at-login=no
/system ntp server
set enabled=yes
/tool mac-server
/tool mac-server mac-winbox
