need automatically delete Expired user
hello anyone
i use user-manager v5.17 on routerbord RB750GL. can i automatically delete Expired user by scrip ?. Please show me.
Thank you so much
First, I do not use the built in user-manager, so use the following at your own risk…
I believe what you are looking to do can be accomplished with the following scheduled script set to run at regular intervals:
/tool user-manager user remove [find credit-left=00:00:00]
I find very little documentation on the user-manager command line syntax (most refers to web interface), so without the user-manager package installed I cannot say the above is 100% accurate, but it should be enough to get you were you need to be.
I created a script for the same exact problem, and so far it works like a charm (link at the bottom).
I run it nightly and so far never failed :slight_smile:
Mind, I only tested it on 3.xx, so 4 and 5 are uncharted territory.
If you can test it on 5.xx and let me know, it would be great!
http://forum.mikrotik.com/t/solution-automatically-clean-expired-user-manager-accounts/47558/1
