Dear Senior,
If you don’t mind I would like to know about BGP problem solution. If you have enough time to give an answer, I will be beneficial. Thanks in advance.
I have two UPLINK, A and B.
I am using two series IP block from Apnic and both are /22 block. (like 103.68.X.0/22 and 103.230.X.0/22)
Now I configured BGP in my CCR-1009-1S-1S+. Uplink A in ether1 and Uplink B in ether2
I set instance, added peer, network, routing filter, firewall mangle, routes, dns everying. I passes 103.68.X.0/22 by UPLINK A and 103.230.X.0/22 by UPLINK B. Everything is working fine. My users are connected internet via PPPoE and there is no complain.
Now problem is–
When I am trying to make ping 8.8.8.8 from my router winbox, new terninal to UPLINK A is getting ping smoothly. But when I am tying to make ping 8.8.8.8 with same process by UPLINK B then its not working. Showing timed out. But under Uplink B from a computer cmd I am getting ping to 8.8.8.8.
I am making ping from winbox new-terminal.
ping 8.8.8.8 router-table=A (Its working)
ping 8.8.8.8 router-table=B (its not working. Getting timed out)
Please help me if you can to solve this issue.
Kawsar
