I have the Metal 2SHPn mounted on top of my boat (6db omni antenna that was supplied), connected to a WD dual band wifi router. I have 6.3.1 OS, I only want to connect to wifi providers and access via the hotspot on the boat. Can someone explain to in layman terms how to best configure my system for maximum signal strength? Currently I am less than 1000 feet (unobstructed) from the marina wifi antenna, but only getting a weak signal. BTW, I am using MAC based devices on the boat. Is there a configuration manual? Thanks in advance!
See wiki.mikrotik.com. You should have some general network and wifi knowledge.
That’s the problem, I am a rookie, and as such, don’t understand the technical jargon. Hoping to garner simple advice for my application. Thank you!
Please upgrade RouterOS to v6.33.1 and then BIOS to the latest version. Here are the links to the documentation how to do that:
http://wiki.mikrotik.com/wiki/Manual:Upgrade_RB
http://wiki.mikrotik.com/wiki/Manual:RouterBOARD_settings#Upgrading_RouterBOOT
What wireless client you use and see that low signal? How far from the AP your client is located?
I have 6.33.1 and I upgraded “router boot”, thank you. Please explain AP and client.
My goal is to connect via the Mikrotik to a wifi signal, then connect with my laptop, iPhones, iPads via wireless router on the boat.
Thank you!
Thank you!
