Hi friends,
I’m using system as mikrotik upto now it is fine…now my hard disk getting some abnormal sounds, what i have to do if i lost my hard disk…
Thanks in advance…
Hi friends,
Thanks in advance…
Make sure you have a proper backup of the running configuration.
I don’t know much about licensing but maybe you need to get an updated if you need to reinstall after harddisk swap.
i was unable to open files menu in mikrotik…and just now i saw my license will expire in 23 hr.
i’m running my server from last 4 months..i dnt know what to do please help me please…
if your hard-drive is shot, you should be good provided A; You wrote down your license key
and B; you have a backup of your configuration.
If you dont have your license key anymore you will probably have to buy another license. You could beg support@mikrotik and see if that gets you a new key, it didnt work for me. Fastest way would be to find a vender of licenses and get it bought and applied before your 24 hours expires.
why it will happens??? I mean any particular reason???
