I have two cisco routers connected via the internet usnig the same asn for the bgp sessions.
Router 1 has a mikrotik behind it also running bgp. Router 2 is advertising net 2.2.2.0 via bgp
The 2.2.2.0 route is received on router 1 and all my cisco routers behind router 1 running bgp because I have used the Cisco command:
neighbor x.x.x.x allowas-in.
However, the TIK detects an as-path loop and does not install the bgp route 2.2.2.0 in the routing table, I have confirmed that router 1 is sending the route to the tik and by checking the log on the tik I have confirmed the the route is being rejected because of the “as_path” loop.
Is there any way to tell the tik to accept the route?
Running 3.14rc1. Also tried on 3.13
