Need for wireless Speed, higher speed than R52nM
Hello Folks!
We need higher wireless speed than R52nM offers at lease twice that is needed.
Which UWB boards is available ?
There are some interesting articles about higher WiFi speeds:
http://electronicdesign.com/article/communications/The-Future-Of-Wi-Fi-UWB-And-The-Less-Known-Wireless-Technologies.aspx
From the article:
UWB uses the 3.1- to 10.6-GHz band and can achieve data rates from 53.3 Gbits/s to as much as 480 Gbits/s at a range of up to 10 meters.
so repeater every ten meters ?
use 2 X R52Hn cards = double bandwidth..
how much bandwidth do you need?
i suggest licensed devices
Hello Folks!
repeater every 10 meters, nice not very practical :slight_smile:
I would need at least 200-500 Mbit/s
If you’ve got some money to spend… : http://www.lightpointe.com/products/default.cfm
Thank you WirelessRudy!
The devices looked expensive :slight_smile: but exactly what we need!
Anyone with experience of those devices ?
I have budget of 5000 euro for a first test setup.
I will ask them if they have dealer here in Sweden.
When I did my military service we did use LASER links, but they worked to satisfactory only 10% of the time :slight_smile:, but that is some 18 years ago now.
I did remember you work in a city like environment, where their stuff is perfect.
I have been looking at it and got some specs and had some communications with sales. I would have liked to use it but for me to far out of budget. Good luck with them. I think it does serve your needs… :smiley:
