I have a user that has a cottage and a small guess house about 150 yards away.
The cottage has wifi coverage no issues. They would like to get wifi coverage to the guess house.
Can someone recommend mikrotik hardware to get good signal?
Thank you
Thank you
This seems applicable.
https://mikrotik.com/product/wireless_wire
Assuming you have LOS between the Cottage and the Guest House.
Then an access point attached to one of the above units or a switch then access point etc, will take care of wired and wireless at the guest house.
For overkill you could look at these
https://mikrotik.com/product/wireless_wire_cube
