Need Help about configuring routes
I have just installed my mikrotik but now I have some problems. I have configured my PPPoE Server, Profiles, PPPoE Users to connect to my PPPoE server, I have configured my DNS servers, they connect succesfully to my PPPoE Server but I dont have internet, maybe routes problem. I have attached a pic that describes my current situation. I put IP addresses i respective interfaces, enabled interfaces, I configured default getway to public interface, I can ping any IP. I put 10.0.0.1 as local address for my users and IP from 10.0.0.10-10.0.0.100 as remote IP. If any one can help me, what to do in this case.
Either you should NAT from 10.x.x.x to 192.x.x.x or you should put a route in the 192.xx gw pointing to 10.x.x.x through the .2 interface of the MT.
/Henrik
AOA
good pic
your problem solved or not
Yes I solved the problem it helped me to configure. Thank you very much for your help.
