humlhr
August 10, 2011, 6:25am
1
I have 4 DSL wan connections and one LAN . I want to Marge them with load lancing. But I have a problem my tow connections are 2MB and 2are 4MB. How I can make mangle between them and route them.
They all are connected in PPPOE mode
plz tell me any example.
i don’t now how to past the diagram in this bloge
Davis
August 10, 2011, 1:58pm
2
Here is similar config with 2 internet links with equal speed:
http://wiki.mikrotik.com/wiki/Manual:PCC
In your case you will need 6 PCC rules that will divide traffic between 4 connections:
/ ip firewall mangle
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \
per-connection-classifier=both-addresses:6/0 action=mark-connection new-connection-mark=DSL1_2Mbps_conn
per-connection-classifier=both-addresses:6/1 action=mark-connection new-connection-mark=DSL2_2Mbps_conn
per-connection-classifier=both-addresses:6/2 action=mark-connection new-connection-mark=DSL3_4Mbps_conn
per-connection-classifier=both-addresses:6/3 action=mark-connection new-connection-mark=DSL3_4Mbps_conn
per-connection-classifier=both-addresses:6/4 action=mark-connection new-connection-mark=DSL4_4Mbps_conn
per-connection-classifier=both-addresses:6/5 action=mark-connection new-connection-mark=DSL4_4Mbps_conn
More info on PCC:
http://wiki.mikrotik.com/wiki/How_PCC_works_(beginner)
Also for failover create 4 default routes without routing marks. Set distance=1 and distance=2 for routes to 4 Mbps connections, and distance=3 and distance=4 for routes to 2 Mbps connections.
humlhr:
For complete detail and answer view this topic
http://forum.mikrotik.com/t/merge-2-dsl-lines-and-give-high-speed-to-your-clients/46109/1
hope you will got your all settings from topic.
humlhr
August 11, 2011, 6:02am
4
thanks for your replay
in this configuration i have a question. i have not equal speed DSL connections 2 are 2MB and 2 are 4MB so when i apply your mangle rules how they work equal. some packet traffic slow and some fast ?
i want to merge tow 2 MB connections and then attach them wit my 4MB so that they give equal results.
i that case i have
2+2=4
4+4=8
in total
4+4+4=12
plz help me
Answer was given in posts above.
humlhr
August 11, 2011, 7:54am
6
ok thanks i will try it
thanks again its relay helpful for me
