Need help about sstp client in Mikrotik RB750
I buy an sstp US vpn account
what i got from them is following
Username: xyz
Password: zxy
This IP: aa.bb.cc.dd is associated with this account.
Server host names for manual configuration: (** please ignore this
section if you will use automatic dialer provided below)
US Server host name: bb.vpn.net
but when open mikrotik sstp client
i got following option like
Connect To=bb.vpn.net
Port=443
Proxy=
Proxy Port=443
Certificate=
User=xyz
Password=zxy
Add Default Route#
but when i press connect i get following info in my mikrotik LOG
4:32:59 sstp,info xvpn: connecting…
04:32:59 sstp,info xvpn: terminating…handshake failed
04:32:59 sstp,info xvpn: disconnected
I need help on this
You need to use certificate, Import certificate to the router then in sstp client use that. I think it is the point.
Thanks Brother
but what i need to know is “do i have to create my own certificate where i will put what information or i have to take it from the vpn provider”
:slight_smile:
You need to ask your provider for it.
how will i import windows certificate into mikrotik router.if you can describe me it will be a big help.Thanks
