i want to create a link about 200-300 ft away and get as close to 800Mbit/s as possible. right now i have a pair of sxtsq 5 ac and can barley get 300Mbit/s TCP. i dont know what hardware to choose since the one i chose before claimed 866Mbit/s im scared to buy another device that claims something it cannot handle. i would like a direct a-b ptp bridge. this bridge will be in the emptiest of areas with almost no interference. i dont know what to buy what should i get?
With 60 Ghz antennas you can get more throughput, but I not know in TCP. With UDP, no problems.
Regards.
What are the settings you’ve used on the current hardware (sxtsq 5 ac)?
The 866Mb/s is probably “Radio” speed, which will equate to approximately 50% of that for Data Throughput due to wireless overhead, etc.
I recently replaced a Mikrotik LHG 5 AC wireless link with the Mikrotik 60GHz “Wireless Wire” product, end result is I have XBox / PS4 gamers on the other side of the link smiling and thanking me.
At the moment have 2 x “Wireless Wire” 60GHz products from Mikrotik in production, and to date quite impressed by them.
I suggest wireless wire dish https://mikrotik.com/product/wireless_wire_dish
hi thabnks for they replies. my link handles alot of movie streaming and alot of ipcameras running about 1MB/s. for the price i paid for my RouterBOARD SXTsq G-5acD it works pretty good but i need more throughput i would like it available when i try to transfer large files through SMB ill look into their “Wireless Wire” 60ghz links. my current setup is ptp bridge no routing. by turning the mtu to max.. i can get a lot higher throughput but its still not enough. i have the firewall off im using 802.11 5ghz wpa2 aes. NV2 yielded about half the speed of 802.11 on 801.11 i get around 650Mb/s udp and 350 tcp.
