Need help configuring port bridge!
Hello everyone!
I’m sure my issue is a simple one, I’m just not used to the completely bare interface of Mikrotik devices and am completely lost in all the options. (I’m mainly used to working with UniFi devices which offer a bit more guidance in setup.) I acquired a MikroTik hexS through my work, and since I was in need of some new home network equipment anyway, I picked up a MikroTik cAP to go with it. Everything is working well as is, except I need to configure some bridging.
My current setup is as follows:
Cable modem → cAP Home AP Dual(192.168.xxx.0) → hexS default(192.168.yyy.0) → Computers
Initially I tried to have them reversed, but the only way I could get WiFi working the way I wanted was with WISP AP mode with the hexS doing all the DHCP, and it was flakey, so I swapped them. Most of my personal devices are wireless anyway, with the exception of two desktop computers, so this arrangement kind of makes more sense anyway.
What I need to accomplish is to have eth4&5 on the hexS get their IP addresses from the cAP so that they are part of the main network.
Eth2&3 will be used to isolate computers I am working on from my personal network.
I appreciate any advise anyone can offer! Thank you!
That seems like bass ackwards to me??
Put the HEXS as the main router attached to the modem.
Add the capac to the HEX.
This all works fine.
I use vlans for example but not necessary if you are using ethernet ports to divide your network.
Like I said, when I had it that way, WiFi would only work if the cAP was in WISP AP mode and was very flakey.
Also, since most personal devices in the house are WiFi, it makes more sense to me for the cAP to be running the show.
Also, with the hex at the end of the line, I have 4 open ports instead of just 3. I realize that technically I would also have the second port on the cAP, but this feels cleaner.
Regardless, even if I had them the other way around, I would still need a couple ports on the hexS running on a different IP structure.
If you someone can help me get everything configured in the best way, I would greatly appreciate it.
Capac works fine starting with default mode of WISP, I have two of them,
then attached them to my router via vlans using this guide.
management vlan (same as home vlan in my case), and three other vlans, one for devices (video, thermometers 2ghz), 5ghz homevlan, 5ghz for guests etc…
They would all go out one port on hex to the capac directly or in my case through managed switches. Leaving other ports on hex to other uses etc…
