I have a very basic setup and I need guidance. I had been using consumer grade router and new to Mikrotik configurations. i’m still learning
Currently, ether2 is master and ether3,ether4 and ether5 are salves. ether5 is connected to a gig switch.
I want to make ether4 a seprate port with it’s own IP of 10.0.8.0/24 with 5 addresses and port speed of 100 mb.
Any help is appreciated.
# jan/30/2018 17:47:23 by RouterOS 6.41
# software id = S1MG-NEED
# model = RouterBOARD 750G r3
# serial number = XXXXXXXX
add admin-mac=XXXXXXXXXX auto-mac=no name=bridge1
set [ find default-name=ether2 ] name=ether2-master
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
/ip hotspot profile
add name=dhcp ranges=192.168.4.10-192.168.4.100
add address-pool=dhcp disabled=no interface=bridge1 name=defconf
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
add comment=defconf interface=ether2-master list=LAN
add address=192.168.4.1/24 comment=defconf interface=ether2-master network=\
192.168.4.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1 use-peer-dns=no use-peer-ntp=no
add address=192.168.4.0/24 comment=defconf gateway=192.168.4.1 netmask=24
set servers=192.168.4.5
/ip dns static
add address=192.168.4.1 name=router.lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/Chicago
/system identity
set name=hEX-1st
/system ntp client
set enabled=yes primary-ntp=97.107.129.217 secondary-ntp=66.135.44.92
/system ntp server
set enabled=yes manycast=no
/system routerboard mode-button
set enabled=no on-event=""
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
